Hey guys Im in the middle of installing my TB and as I'm plugging everything in I noticed that the tps sensor sits very close to the TB, so close that it is difficult to get the plug on the tps.... How do I get around this???
grind off the back of the connector and locating tab to allow more room// depending on the time it was made u may need to space the tps out using small washers and use longer screws
ok ive ground down the plug and put little washers in... Good clearance now... Thanks Dl.
