So heres the deal, i have a +6 swingarm and im tired of bottoming out and how low my whole quad sits. I already have the 700 SE shocks on the front and it sits much higher as well as rides MUCH smoother, now i just need to deal with the rear. I am am leaning towards the route of respring and revavle but with a +6 do you need a longer shock or am i completely wrong
thanks in advance for the help
jeff
Get ahold of a shock builder and they will set you up right. There is a forum soonare here that does them. He will set you up with the right setup and awnser your questins. I know you will need a re valve and new spring though.
A-10 Crew Chief
PM preddy08. He is the RF contact for Josh at wiigstyle who specializes in shocks.
We threw a 500lb spring from GT Thunder on Sand84's quad a few weeks back with his +6 swingarm, and it worked out great for him. He had a shaw on it, but it was WAY too stiff...so the stock shock with a heavier spring worked out great.
thanks for the help guys, much appreciated
