ok so where does the hose between the carbs go......the one with the big spring on it does it just hang out under the seat or where
if its the hose i think your taling about it should have a clamp on each side of the spring. these clamps have threads and the hose wraps up and around the inside of the metal brace in the middle of the frame.its the piece your carb cover connects to.ok so where does the hose between the carbs go......the one with the big spring on it does it just hang out under the seat or where
