1 - 20 of 21 Posts
Hi all i just got together a full scorpion system yet to be fitted
i asked the dealer for the jet kit but only recived 2 jets in the bag is this normal i was just expecting more.
it depends on what other mods you have...air filter, airbox lid removed, you should buy larger pilot jets as well...whats done to your motor?
Git-R-Done
With no mods to motor and just a pipe i would do 155L/160R carb. I did the 160L/165R and i have dual pipes with no lid and it was to much so i moved back to the 155L/160R carb if this will help some and im right on.
i have purchased them now and the quad is running mint will i really need to use these i am going to make a start tommorow and take my old one off
tmc what do you mean by they were too much ?
another question is is the left/right carb i presume if your sitting on the bike looking down on it
thanks
Git-R-Done
it mad my bike bog down and yes when you are sitting on your quad looking forward would be left to right. when i put the 155L/160R my quad runs like a top no more bogging.if you got you pipe on now and it is running good then don't mess with it.
No mods, bike runs well - might not be necessary at all, but might be worth a shot. At least tryin them out you'll get familiar with the process and the carbs themselves. All it takes is time at this point.
He means he thinks they might be a bit big. Stock jets are 140/145, and yes - that would be as you sit on the quad, with the carbs mounted :beer:
thanks for the responses guys so am i right in saying if i fit the full exhaust sytem and it runs mint
which it does now just stock
just leave it and do the jets for another day or sell them.
Git-R-Done
you got it.;)
TMC.
What type of airbox are u running?
I have a pair of LTR duals coming, so i was thinking what would be the best setup for the duals?
My 660 is stock at the current moment.
Best setup depend on how/where you ride. No lid will give you better flow/power, but might not be ideal if you ride through some real wet conditions.
Git-R-Done
TMC.
I have a aluminum airbox with a K&N air filter with no lid. my jetting is 155L/160R with the fuel screw's 2 1/2 turns out. plus i have vito's jet kit it has everything you need in the kit to jet your carbs.
I'm surprised... 155L/160R Mikunis is a bit on the lean side for open airbox, especially with duals. Of course, every bike has its own 'personality'.
Git-R-Done
QM i tried to change to 160L/165R and it made my quad bog down in second gear when i got on it climbing a hill. so i looked at the vito's instructions and it said i should be set at 155L/160R. If i had a cam and bigger piston i could use the 160L/165R acording to the vito's instructions.
Understood - but most open boxed bikes are running 160L/165R or 165L/170R... and with your duals, I'm just surprised... not to say it's wrong - what makes YOUR bike run good is what's right for you!
1 - 20 of 21 Posts
