1 - 14 of 14 Posts
i cant seem to be able to remove the sparkplug what size socket is needed????
what is the most reliable plug??
I been told in here 18mm i tried a craftsman and it wouldnt fit also maddog said he thought it was 17mm I was only able to get it with a sparkplug socket tool that came with a honda recon. Maybe someone can help further solve the question cause i rather use a socket than the anoying adaptation i have to make useing the tool with crowfeet wrench to small extentsion to torqe ratchet is annoying but i like the old rusted tool it hold the plug to be able to pull it out. If you cant afford to wait are order the tool than I hope someone can tell us what size deepwell and what brand they are useing. If i remember correctly the 18 fit the plug out of box snugly I been doing so much to raptor and parts buying i forgot but down in the hole it would not fit over the plug.
I also use ngk r plug from autopart store nothing special standered plug for 3/4bucks.
Heres a question for anyone who used differnt plugs. Whats best? how much better is a ngk irrduiem over reguler ngk r?
17mm fits on the oem plug tool, couldnt tell you what the plug itself is.
Do they come pre gaped? Mine was right on when i use my feller gauge. Also should i attempt smaller/bigger gap to tune the plug are just leave it alone?
Also lol Im a millionquestion man why do you run standered and not the higher doller ones? same performance lower cost?
Because anyone who thinks iridium is making a difference in this engine needs his head checked. :thumbsup:
Most are gapped pretty close, but I check them anyway.
firstraptor said:
Should I take the head off to check it or can it be checked without removing?
:wtf:
firstraptor said:
Sorry, I'll try to restrain myself in the future. But it's not a promise.
For some reason I didn't notice it was firstraptor's post, I thought it was akawilliam and was a serious question.
Now that I look, I gotcha. :thumbsup:
1 - 14 of 14 Posts
