When I give it wot is baxckfires and bogs a littleflame shoots out the exhaust and the head pipe get cherry red quad starts fine and idles good only happens at full throttle I cleaned the carbs and still does it? Please help can it be timing?
It could be a lot of things, have you modded the air box, removed the snorkel..............
WHat did you do last, or how long has it sat, unused?
So did this problem start before or after you cleaned the carbs?
Yes, 3 in left - 140 main, 122.5 pilot, 80? choke; 2 in right 145 main, 122.5 pilot.
OK I figures it out the threaded part where choke cable goes into carb was crossthreaded and at full throttle it would suck air in from that part and cause it to lean out. Thanks for answering guys I was on other forums no one attempted to even try tohelp
There really is only one worthwhile forum and you've found it! Don't be a stranger.
