1 - 20 of 20 Posts
Whats up guys. I should be gettin my motor back from trinity racing this week and i was wondering if anyone could give me any advice on jetting. I got a 686 big bore kit, head ported, new valves, new cam, and 11:1 compression piston. Also i would like to say i was very dissapointed in trinity racings customer service. All this cost me 1350 dollars and once they had my money they were very little help. I havent recieved my parts yet but it better run like a dream without any problems.
Jetting specs depend more on your air box or lack of it then engine mods..............
Give us a list of the mods done to the air box and exhaust...........:)
My tip is: dont tighten the pilots too tight they can break off. If it does happen you may be able to get lucky and counter-screw it out with a jewlers screwdriver since the brass is soft.
I get my Technical advice from WillyKiller
JimT
That is a pretty common theam with Trinity Racing. About the only thing I would get from them is a Billit Intake for FCR carbs, but I wouldn't buy it directly from them.
Need all the info so we can give you the right jetting specs...
i need some help.. i have a 05 686 yosh full,cfm air box no lid,k&n filter, i have the dyna jet kit in it right now runs good but low on mid range and when i get out of the gas it backfires. it has #25 pilots,146,148 mains 2.5 turns out and on 4th from the top on needle.. i live at 480 feet above sea level.. i just ported the intake runners and ordered 160,165 mains.... WHAT SHOULD I DOOO!!! PLEASE HELP THIS SUCKS...
Also i can runn it with the choke all the way on and it dose nothing
Have you tried raising the needles...........
If it back fires when letting off the throttle it is a little lean on the pilot jet circut / fuel screws. Changing the mains wont help.
I would make sure the #25 pilots and the carbs are clean. You shouldn't need any larger pilot jet. You can try to turn out the fuel screws a little more but I would make sure the pilots and carbs are 100% clean first.
Discussion Starter · #10 · (Edited)
Hey thanks for all the feedback guys. I have the air box lid removed and a k & n filter. 686 bore, 11:1 compression, stage two cam, +1 valves, port and polish job, fmf powerbomb header, pro circut t4 pipe. I ride anywhere from 3500 to 8000 feet. Also any idea on how high octane i need to run. Ill never use trinity racing again but I will say that they do good head work. Before with the stock piston, bore, cam, and head i was running 155 and 160 main jets, 22.5 pilots, and the needle in the middle slot. Thank for any info you might have.
I just got it back together so I haven't messed with it much yet. I was just hoping someone could get me close on jetting so i dont end up running it to lean and i dont have to rejet fifty times.
What type of exhaust and how is the airbox modded.............
You're going to need 25 pilots, and probably 1 step higher on mains (160L/165R) or so.
Discussion Starter · #14 ·
I have the air box lid removed and a k & n filter, fmf powerbomb header and pro circut t4 pipe. Also what octane fuel would be good to run? I ride anywhere from 3500 feet to 8000 feet. The st. Anthony sand dunes are around 5000 feet so i would really like it to run good there. I think i might end up getting an aem air fuel gauge.
93-94 pump gas will be fine..
Big variation in elevations! What you have now might be okay for 5000'.
Discussion Starter · #17 ·
Thanks for all the input guys. I really appreciate it. This raptor forum is awsome.
Discussion Starter · #18 ·
Well just an update. I took it for the first ride today and it ran great. I checked the plug when i got back and it looks good and tan. I think all still put 25 pilot jets in just to see but besides that i think its good. I am running 160/165 mains, 22.5 pilots and the needle is set with the clip two notches from the bottom. Elevation about 3500. =)
Good to hear..
K i just bought a vitos jet kit because of the aftermarket needles and the air/fuel screws. I was wondering how different the needles are from stock. Im on the fourth clip from top right now with the stock needle and was wondering if that would be a good place to start with the new ones. =)
1 - 20 of 20 Posts
