1 - 20 of 22 Posts
Just rebuilt my motor and raced AVE last week, had a great race and all seemed well. When I got home noticed Oil in my Radiator fluid...
Turns out that the double head gasket is known for this and you need to use a product called copper cote that will help to expand and seal the head gasket. Thought I would share with all you motor heads...But you probably already knew!
Are you yelling Brett? LOL
Ya My buddy Bill actually told me to go to High Desert Dyno if I cannot get this right...He loves those guys...Thanks for the second opinion!
When you say "double head gasket", are you talking about using two (2) gaskets or is this the name for some special gasket?
No its a two piece gasket and when you torq it to the right setting the sealent that it has on it is supposed to bond together and so you dont need to use other types of gasket sealent. I recommend that you do,
Im not the best motor head so was wondering if others had the same porblem.
I got my gasket from high desert dyno. It is a SCE copper head gasket and he sent some sealant to put on as well. No problems yet.
Is this a big bore? I thought the stock head gaskets are a single piece if I remember right? Its been a couple yrs since I last rebuilt mine.
So ummm again, how do you apply the copper coat? I'm thinking about using it this time around and i would like to get it right if I do. Is it applied to just the parts of the gasket that come into contact with the surfaces of the head and cylinder or is it also applied in between the layers?
Discussion Starter · #19 ·
Cleaned the surface of the the head and sleeve case. Applied the coppercote on both pieces waited for them to get tacky. Used a fair amount but not like gooped on just a nice even layer, then applied gasket on to sleeve with pins placed in sleeve instead of head where they always come out...so far so good. Racing saturday so let you know =-)
and yea it was a mulit layer steel. I thought it was made by protec but may be cometic...I went with the OEM this time as my Piston is stock...
1 - 20 of 22 Posts
