1 - 12 of 12 Posts
I was just looking for some input. Is it worth replacing my 06 front shocks with shocks off of a newer model? Or should i just invest in some great aftermarkets?
It's definitely worth it because it's really cheap. They aren't the best shocks, but they are 100x better than pogo's.
If you get a set if rezzis and you have them tuned they can be just as good as aftermarket ones. Like qcraptor said they're 100x better than pogos.
Ridin High.....
i duno about just as good as aftermarket. but definatly an improvement over pogos...imo
Well that's what other guys have been telling me but I'm sure to get to that level it's gonna be a few bucks more than a normal service job.
Ridin High.....
yes. you can even run 04-08 YFZ shocks...
the 450s will lower it and the 450rs will raise the front end, all 700s will work and not change the height. I think the 450xs will keep it the same as well but I'm not 100% sure on that.
Don't think you can use the R's, they are LT and WAY to long for stock location. The X's can be used when pre load is all the way out, but from what I've seen it will raise it a hair. But not much.
1 - 12 of 12 Posts
