1 - 13 of 13 Posts
Got any pictures?
I use a light weight arena dragger behind mine to make quick work of the yard.
What's your setup like? I'm on the fence between building and buying.....so it'd be awesome if while we wait on the Outlander I could take care of our arena with the rappy.
Always wanted to see how a raptor would do with weight behind it. They pull like a train unloaded, I think they would tow well. An upgraded clutch would help a lot
Discussion Starter #8
I did change the counter shaft sprocket "smaller" to gear it down on both 700 raptors so when I was in any tight spots I wouldn't have to slip the clutch to go slow with a load in the trailer. Where I live there is a lot of rocky/steep trails and I'm not interested in going as fast and being 60 years old I'm not the hot rod I once was, also I have visitors that ride them and geared down a bit helps them with putting on the steep stuff and riding in general.
Agreed. I run the 13 tooth on slow rough trails, 14 in general, 15 for nothing but fire roads.
1 - 13 of 13 Posts
