GEARHEAD9969 said:
nope it was with the direction of flow, the adapter I.D. was smaller than the rubber. I just opened mine up to match the rubber joint.
Exactly! That shouldnt hurt flow. If it was vise-versa it would, because you would have a lip protruding out and interfering with the flow of air. In this case nothing is protruding....its just a "step down"....which to me wouldnt make much, if any, difference.
Air is traveling in threw the filter...then it hits the adaptor which must be rounded, otherwise your intake air would be turbulent...then it goes threw the adaptor and goes into the intake boot, never once "hitting" that seam between the adaptor and the boot ( its going right over it)...BECAUSE the adaptor is in fact smaller than the boot. If the boot was smaller than the adaptor then yeah, it would effect the flow. I dont think "step downs" would effect flow. "step ups" would however...and in this case the step up is on the outside of the adaptor on the filter side. Its all rounded and honed very nice. On the back side (boot side) it doesnt "have" to be honed perfect because the air is just being dumped into the boot and traveling up to the TB.
....If you turned your motor into a blower instead of a vacuum I could see your point, cause that joint between the boot and the adaptor would be against the direction of flow.....
I did go look at my prodesign and the lip of the adaptor is rounded smooth on both the intake filter side, and the boot side....
