1 - 16 of 16 Posts
Went on aliitle ride yesterday and the raptor took a lil spill. I got stuck on a hill so i jumped off and thought i stabilized my bike. While i was tellin my friends that there was ice in the spot i got stuck at my rappy started rollin down the hill. It made it all the way to the bottom and took a little roll upside down. Now when it runs it increases throttle on its own! If i put my bike in neutral and let it idle it will start revving up on its own. If im in first gear just drifting it even pulls a liitle bit like im slightly pushin the throttle. Has anyone heard of this if so please tell me whats wrong cause im really pissed off and i hope its not pricey to fix. My handle bars seem to be bent also. Can anyone give me a good test to see if i bent my steering stem. Also does new handle bars fix toe in? All of this happened from what i thought was little wreck :mad: :mad: :mad: :(
I just took a look at it and i broke it im about to post a pic!!
snapped right off!!!!
another view. that would probable explain the revving up for no reason
that would do it
hopefully the replacement parts aren't too much, might want to get new bars too
Something else that might make it rev is an air intake leak.. Just a thought! Good luck on your repair :thumbsup:
another throttle box can be found real cheap off ebay....YFZ throttle boxes work also but id reccomend a Honda Throttle, the difference in the lever angle will be so much easyer on your thumb than the stocker
how much would u buy my throttle for including shipping? I was thinking about getting a motion pro twist throttle.
I already took her to the shop to get everything taken care of. thanks for the offer though
that happened to me, the first day i had my bike, when i brought it home, i took it for a ride, and ended up rolling it..... I tried like JB welding it back together... nothing worked.... so i got on powerpartsplus.com and went to the raptor 700 schematics, and just order the piece from them.... think it was $70 or something like that...
Plattner
What honda throttle assy will work on the Rappy? I replaces mine already but it's a poor set-up and way to exposed.
Any of the Sport Models and most the Utiity models should work......there the same type of clamp and all just different leverage
Cables mount up the same?
1 - 16 of 16 Posts
