Ya know...it's funny that when your really into being the fastest around and buy parts to get there you still could loose. I was thinking about the stock 700 falling off at 6k give or take a few hundred RPM. When I was dragging my busa we found the peak HP and had a shift light to let you know when your there. If you went over...it slowed you down and vice versa. We need to find a small lighted shift light that would/could mount on the plastic cover for the bars. This way while riding you know when to shift either racing or playing around to keep it in MAX HP range.
Does anyone know/use of something simple you can set as a shift light without adding tons of weight or complicated wiring? It has to be done or avaliable somewhere to help us keep it where needed!!!
MIke
MIke
