1 - 19 of 19 Posts
Hey I need to adjust the rear shock. Can someone explain how to do this and how the different adjustments will affect the ride? thanks
I hate to be one of those "read the manual" guys but looking at pages 16 and 17 in the owner's manual could be helpful. ;)
Are you wanting to adjust compression and rebound on the shock or do you need to adjust the pre-load on the spring as well?
there are a few good threads in the suspension section, have a look through those, you should get some good tips there
MK
I dont konw what the compression and rebound means but the rear is bottoming out when doing jumps so i think i just have to tighten the spring.
spray the threads with some wd40 then use a large screwdriver and a hammer to turn the collars
it will look like poopie after that,go to a tool store and buy a spanner wrench.....keep it in your truck so if and when you need to adjust you got the right tool.........
I just jacked the Quad up and after i got the holding ring out of the way i adjusted the spring by hand....without any pressure on the spring they adjust extremely easly
i did mine by Hand-mer also, once it was loose,it turned easy, made a big difference,i adjusted mine as much as i could cuz i weight in the 260's, helped a lot, i didn't bottom out at all last time i rode,...i smashed my nuts between the seat and my ass :eek:. but i didn't bottome out!!!haaha :thumbsup:
free ballin while ridin the trails is not cool :grin_nod: :grin_nod: :grin_nod:
... so where did your screen name come from, Loose Nutz? ;)
loose screws in my head is what my buddies keep tellin me, i'm a diesel mechanic and don't really deal with screws just nuts and bolts, so i used loose nuts. i think nick needs to check this out though it may help keep him from sittin on them again....
http://www.muttonbone.com/store.html
oooppps wrong one,,,,check this out for those saggy balls of yours so you don't sit on them again........... :thumbsup: :thumbsup:
btw, hey nick krandall will appreciate you for this one.... :lol: :lol:
http://www.devilducky.com/media/34116/
ahaha, yeah i gotta get that one, that will help tons!!!>
:google:
I get busted nuts sometimes on the jetski, wow there is nothing more painfull.....somtimes that shoot up into my throat! :crazy:
1 - 19 of 19 Posts
