I tried to search for this topic with no luck. I need to know how to adjut my valves. what are the specs and every thing that goes with doing this job. I haven't looked in the manual yet (I know I should do that first, but I didn't) Does any body have a pictures of them doing this? I have adjusted valves before on a VW is it similar? :help:
It's similair. You need to remove all the plastics and gas tank to get to the valves. Then open up the side cover of the motor and set the motor to TDC of the compression stroke, there is a tick mark on the flywheel that tells you when you're there. The specs are .006" for the intake, and .008" for the exhaust.
