ok guys i was new to adjusting the valves on the raptor and i followed the DIY write up and after everything was done I put the valve covers back on and reinstalled the gas tank and fired it up. Some reason the motor sounds noisy when I started it up. The valves were really tight so I loosen them up to around .012 intake and .018 on the exhaust side. Im going to go back and recheck them today. Any input would be helpful thanks.
The UK's fastest Raptor
hello bud,
looks like you might be a little out on your clearances.
Manuals says:
intake 0.09 - 0.13mm (0.0035 - 0.0051 ins)
exhaust 0.16 - 0.20mm (0.0063 - 0.0079 ins)
Ez
Looks like maybe you got the inch dimensions mixed with the metric. You are in the range for metric but those are .12 & .18 MM, I bet you set them in INCH. That is easy to do, don't ask how I know.
damn. I think was reading metric. I can't believe i would of done that..ok thanks very much ill recheck it.. and let you know what happens.
