Hello
My balljoint was get out from the lower a arm in a middle of riding so I was noticed that to replace it I need to replace the whole a arm so I just install a new oem lower a arm but something feel difference now the wheel change is angle a little bit from stright he become something like this \ if you can understand what I tried to show xD there is any reason ? There is something in the installing process that I was should know ? The quad doesnt get any strike or something
Thanks
In english that is called castor/camber. There is a thread going about how to adjust front end of quad bikes in the 700 section. Read through that and check out TEAM2GILLS videos he posted, hopefully that will help
Discussion Starter #3
I will check that out.. Thanks
That's not normal. The 350 arms are not adjustable. The only thing I can think of is something is bent, or you put the hub on upside down. Take a picture and post it.
