is the velocity air intake adapter plate hole size bigger or is just the air filter bigger? and what about the gytr from yamaha. do i need to make the hole bigger on the air box? or are all the aftermarket filters bigger in surface area allowing more air. thanks for the help.
The foam filters will obviously have more surface filter area than the pleated onces like K&N/Velocity and GYTR. With the GYTR, all you have to do is remove the bolts on the bottom of the intake boot on the outside of the airbox and lift off the stock filter adapter plate, and replace it with the GYTR, same with the Velocity I assume. I basically did the equivalent with mine...I just bought a K&N air filter, and removed the screen from the stock adapter plate. Same effect without the extra $30-40 for the adapter plate.
Thanks for the info. i will do some more checking on this.
