Does installing aftermarket parts, such as a pipe, jet kit or hi flow air filter shorten the life of the engine?
No. as long as you maintain the correct jetting for the mods you do it will last just as long. If you don't change the jetting when you do elevation changes mods to the intake or exhaust you can end up runningrich or worse lean which will allow the quad to run hot causing part to ware out quickly or even complety ruin the motor. Don't be afraid to make the changes just take the time to adjust the jetting for where you are ridding and check your spark plug often for rich/lean conditions
