1 - 10 of 10 Posts
Im in need of a new spark plug boot, anyone know if NGK makes an oem replacement? i have a NGK one on it now, but its not the right bend so I can't get the rubbet grommets back in place
Breathe my dust !
Do the spark plug mod, you can use NGK ones, they makes "racing cables" with a 5 ohm resistor boot on them, works fine.
well a new oem boot is about $25-30..NGK is $4.
The NGk number your looking for is XD05FP stock number 8641. There like $4 from your local NAPA store. There the same as stock ones and ive been running them since i bought my 660.
Hope this helps. Justin :)
NGK XD05FP sure looks like it should fit the bill -
im pretty sure i have the xb05fp right now and the the section up the elbow is just barely long enough the reach out of the cylinder and nowhere near long enough to slip the grommet into place that plugs the hole so water cant get down around the boot
1 - 10 of 10 Posts
