so i noticed my chain wasnt tracking quite straight after i installed my aftermarket swinger with round bearing carrier, so i got to checking things and its really running not straight, so much so that the front sprocket is wore down on the inside and was probably the cause for my output shaft seal leaking as well.
the only thing i can see that would be causing this is i reused the stock sprocket hub, and it looks to me like the lip on the sprocket hub that is supposed to go in the stock bearing seal on the stock bearing carrier is not in fact in the seal, but riding on the outside of the seal, making everything on the axle over, off to the left the length of that little lip. on further examination, the lip that is supposed to go in the seal, is way to big in diameter to fit inside the seal, and will not fit.
has anyone else had this problem? did i maybe get sold a round bearing carrier for a different bike that has a different inside diameter on the seal, or are all round bearing carriers made the same and you must use an aftermarket sprocket hub? just curious because i havent seen anyone else here have this problem, and i checked out prices just for a sprocket hub is like 160 bucks, a bit steep.
anyone have any thoughts? Thanks!
