1 - 9 of 9 Posts
I used a small screw and drilled it threw the plastics in a out of sight place.
I'll try getting pictures.
Screw it so it goes into the little tool compartment should hold it.
Discussion Starter · #5 · (Edited)
Thanks for the pic, could you zoom out a little bit so I can see where that screw is.
Thanks again
P.S. Where/how did you attach the computer that was on the airbox?
I zip tied it to the sub frame. The screw is right above exhaust just below subframe.
Not a problem.
1 - 9 of 9 Posts
