Hello everyone, here's my thread with the step-by-step to make a homemade EHS type airbox lid. You can do this for every ATV make and model.
First thing to do is, take a picture of your lid with something for scale reference. Then upload it to a CAD program and start drawing, trying to use much area as possible:
Auto part
Font Line Parallel
After that send it to a CNC machine, this is what you get:
Metal Table
For the Raptor 350 i recommend 2 aluminium frames with 2mm (máx), because the airbox lid is curve, so you will have to bend it to get an exact fit. Other models, just need 1 with 4 ou 5 mm
To start the construction here's what you need:
1- Outerwears airbox cover (water repellent), bigger you get, better it will be because of mistakes.
1 or 2- metal frames with the shape you want for your lid. For flat lids you only need 1, for curve lids like Raptor 350 you need 2.
- 5M screws, washers and nuts.
-Silicone
-Epoxy glue
Auto part
Discussion Starter · #2 · (Edited)
2nd step
Let's start the construction:
For the Raptor 350, you will need to cut a bit of the snorkel before you start(Remember to keep the bits for later).
Tool Rotary tool Angle grinder
Tool Rotary tool Cutting tool Tool accessory Floor
After you do this, it's time to mark with a pencil all that is to drill and cut. To avoid error, drill a hole to fix the frame and then mark everyting else:
Auto part Rear-view mirror
Auto part Vehicle Bumper Automotive wheel system Automotive exterior
Bumper Automotive exterior Auto part Vehicle
Step 4
Remember to clean the piece, removing all the sharp edges to avoid tearing the outerwears cover:
Automotive exterior Bumper Auto part
With a blade make some small holes on the outerwears cover, where the bolts will pass:
Auto part Bicycle pedal
Carefully put some epoxy glue around the bolts holes to avoid tearing and let it dry.
(For Raptor 350: after it dryed, join the other frame: Gun
While the glue dries, start putting silicone around the hole of the lid:
Melodica Scale model Hand Toy Finger
Bumper Automotive exterior Auto part Seat belt
Step 5
Time to join all the pieces:
Arm Technology Machine Robot Small appliance
Cut the excess fabric
Everyday carry Tool
And you're done!!
Vehicle
Raptor 350 before you finish it, remember to rebuild the snorkel, use epoxy glue and bits of the lid that you have cut:
Auto part Metal
Hood Bumper Auto part Vehicle Automotive exterior
HOPE YOU LIKED :)
Nice thread. Good info Thanks!
