Hi everyone. Awesome site here and glad to be a new member. Looking for some help with my daughters 05 Raptor 350. I've spent about 2 hours on line here using the search option and I'm still stuck? Parked it last year after dune season and everything was good. Put it on a trickle charger for about 6 months, ran carb dry of gas etc. till dune season again. This January tried to fire her up and no luck! Long story short, it was cranking but wouldn't start and wasn't getting a spark so I tried to do my best to troubleshoot it and had no luck. Dropped it off to a local shop and was told that the stator was bad? The ignition coil and stator were tested while they had it. Just put a new stator it it this week and now I'm hearing the starting relay click with 12.9 Volts at the battery even with the start button pushed. I had the battery charged to 13.2 V. before testing again. Couple of notes: I'm using a small car battery fully charged, relay fuses are good, all electrical connections are good, I have been using my led tester (along with the schematic from the service manual) looking for 12v and have it at the following locations: starter relay from batt. the brown wire from the Starting circuit cut-off relay, red wire from the Main switch, I also have taken apart the on/off switch and cleaned it out. Can someone steer me from here? Thanks!
