So before I jet and do everything (I really wanna try to get it on the first try) Here's my set up
HMF Competition Slip-On
Pro Flow UNI intake (No Lid)
I have a 150 main, and a 25 Pilot. Should I drop one on the clip too? I ride at sea level. Thanks
I have a HMF slip-on, K/N filter with several 1 inch holes in the air box and run a 25 pilot (2 turns out), 155 main, and clip dropped one position on the needle. Ran that setup for 1000 miles last summer between 1000-1400 ft with no problems. Plug was alittle black but never failed.
Keep in mind what controls what.
idle to 1/4 throttle - pilot jet
1/4 to 3/4 throttle - carb needle position
3/4 to full throttle - main jet
Haven't tried it yet but heard a great way to fine tune your jetting is to use a new/clean plug in each of the 3 ranges above. Example, warm engine and put in new plug, run it up to 1/4 throttle for a couple hundred yards and check plug. Once you have the pilot jet set right, do same to the next two ranges above in order. I guess this way will highlight how each of the 3 ranges is performing.
Discussion Starter · #3 · (Edited)
Yeah, i've heard that. I did my jetting and the intake today, i'm waiting on my exhaust to come in and really hopping I don't need to rejet...
EDIT: I forgot to ask, I put the new main in, but I had to leave that cylinder like piece off because this jet was wider. That's fine, right?
You sure you have the right main jet? 150? You shouldn't need to take the cylinder piece off. I have a 155 main and didn't have to.
It fit perfectly, and I ran the bike and everything was good. It was good through all the RPMs. It was a small round Mikuni jet, I got it from a Yamaha dealer, so 'm assuming they know what they were doing...
