Well I put on the LTE's and the bike runs great! Thanks again to Raptor Randy for the custom map!
The question is I have an Elka shock and the rez. hose is really close to the pipe, about 1/8". I pulled it over as hard as I can and zipped tied it. I then put some heat shield tape on the hose and now it just barely touches the pipe. Do you guys think that's o.k.?? I rode it yesterday for a couple of hours and no problems yet.
On the right side the pipe comes really close to the air box. I again put heat shield tape there and it just barely touches the pipe. After my 2 hr. ride I looked inside the plastic air box and it looks fine.
So I'm more concerned about the remote rez. hose because I can't see if it's burning or not. The banjo bolt on the Elka comes out at 9 o'clock, if I could move the banjo bolt down to 7 o'clock it would get more clearance.
My second question is can i loosen that banjo bolt and turn it down, so the hose will be lower, without it starting a leak or would I have to send the whole shock to a shop to move it an 1/8 turn ??
Sorry for the long post. Thanks.
