another PCIII question..
hey guys, my searches came up dry. can anyone please explain the three buttons? like how do you enable them to make adjustment, how long to hold, and what exactly is it they do? i.e. change the entire map or once they are activated do they cancel out the map?
id just play around with it, but im sooo close i dont want to screw it up. it took me two days to get where im at so far. :help:
Discussion Starter · #2 ·
Re: another PCIII question..
....... :unsure:
it should say in the instructions, like for every time you press the button it takes the map down 1% or something.
It basically breaks the current map loaded into 3 sections that you can adjust independently from each other. I forget the exact procedure but Dyno jet has instructions on there website. If want to adjust your map I would recommend doing it on a PC, that way you can see exactly what you are changing and you can adjust it 1% at time as well for the entire map or sections. :thumbsup:
