1 - 14 of 14 Posts
I have the lte duals on and still have the 155l and 160r jets and the needles to come with it ( thinner than stock ) on the 4th clip my bike is running to lean ( spark plug white) and the 5th clip down its running to rich ( spark plug black) any suggestions????
At what throttle postion are you checking it at............and how long did you run the bike at this throttle position............
now its after i take it down the road and ride it about a minute it'll start coughing and cutting in and out. i stop check the plug and it's either white or dark black. i can't find a happy medium.
Is it cutting out with the black plug also......
with black plug it hardly runs... and when you get to 3/4 to full throttle bikes stumbles. too lean cuts out going down the road but no throttle problem. fml...
Up your mains by 5 numbers each and keep the needles up.......
do i need to change the pilots or keep the ones i have in there? i think their 22.5
i just ordered a 25 pilot and a 160 and 165 main jet... hopefullly ill be good to go
when im putting on the 160 and 165 is the left looking at the bike. or would it be from sitting on the bike..?
Discussion Starter · #14 ·
ok. thanks for all your help! got everything ordered hope to be riding next weekend
1 - 14 of 14 Posts
