1 - 20 of 23 Posts
Ok I am peiceing together a motor. And I wanna know what's the best deal on. Lockup clutch and for the best price with the see threw cover.
Also best deal and best stroker crank +5mm. I am looking at the hotrods crank but heard. Couple bad things and good ones.
Also a big bore kit. 105.5mm idk which one to go with. And also does anyone sell a already put together kit for the crank and big bore kit?
Any feedback is a plus.
Also best deal on a +4 swingarm.
I got my big bore stroker kit 778cc 105.5bore and +5HR crank from TQS (tech quad shop ) they're a sight sponcer and a great place for parts. If you're going that route I'd port the head and get at very least the hc3 cam.
Best deal on a plus 4 swinger is outback welding also a member here. They'll extend your stocker for around $300 bucks. Aftermarkets are twice that easy.
I run a stock swinger being I trail ride alot
How much was the kit from them? Does anyone have a pic of the work they do on the swing arm?
Do you have the link to tqs
How do you like that set up and how long have you been running on it?
just search for outbackwelding. I havent seen him on in awile but looked like quality work.
What crank did you go with? Hot rods?
Yep the hotrods +5
Discussion Starter · #14 ·
Any sugestions on the lock out clutch and were did you het that compression piston?
I'm running the oem clutch with full fiber mod and hd springs. Compression is 12.5:1 cp piston then you get another .75:1 from the +5 stroke.
Discussion Starter · #16 ·
Its more of a looks thing for me. But is there anything I need to know with having this motor built anything I need to do when I am in there and should I go ahead and replace the timong chain?
Check everything since its apart I kept my timing chain cause it had about 50hrs on it. I been thinking of a lock out myself just for the extra security.
Discussion Starter · #18 ·
Yeah I think it will be a good idea. But they look really cool. What gas do you run in yours?
Vp 110
Also I noticed you live in ohio. Maybe you can help me do you know anyone that dyno tunes or can tune my bike when I get the motor built. It has the pc3 programmer. I'm not to good with computers or I would.
1 - 20 of 23 Posts
