Great Forum,I am from South Africa and need some advise from you guys. I need to upgrade my wifes 660, only top end.Can someone please give me some advise on what to do. I am going to install a Wiseco piston and 2 stage cam , what else do I have to upgrade, and carb settings. At this stage the quad have a slip on and 145/150 jetting,pilot 2 and quarter turn , closed airbox , standard filter. Thanks:help:
Something else , I cleaned both our 660s carbs the other day and after I re-installed them , the feul keep on dripping from the overflow pipes, I did the cleartube mod as well , every thing seems fine, please help.
quadtorque.co.za
pm Freez on the forum....he is the top dog in SA regarding this...;)
Great Forum,I am from South Africa and need some advise from you guys. I need to upgrade my wifes 660, only top end.Can someone please give me some advise on what to do. I am going to install a Wiseco piston and 2 stage cam , what else do I have to upgrade, and carb settings. At this stage the quad have a slip on and 145/150 jetting,pilot 2 and quarter turn , closed air box , standard filter. Thanks:help:
Something else , I cleaned both our 660s carbs the other day and after I re-installed them , the fuel keep on dripping from the overflow pipes, I did the clear tube mod as well , every thing seems fine, please help.
Leaking needles and seats in the carbs, or you have the fuel level adjusted to high in the carb bowls.............
The cam and piston will get u the top end that you want plus some,,,,
What I suggest which will be better off is get exhaust and a prodesign k&n airfliter and rejet
That will also give you the top end your looking for plus better throttle response
It may be time for you to rebuild your carbs I had to once my carbs tubes started to leak
