1 - 13 of 13 Posts
So ya, im out riding today and next thing I know I have a small stream of coolant spraying me right in the face. So I was wondering if anyone knows a good way to fix this, short of having to buy a new radiator. O ya heres a few pictures my girl shot of me down in our woods. Hopefully soon I will have some dirt jumps on our track.
I think they make a putty that comes in a little tube at like your local auto store or you could try jb weld or some other kind of epoxy, I wouldnt try the egg, tubes in raptor radiator are a little small and I dont think I want a egg in my coolant.
bummer man :(
but this is where we need to know more info on where the hole is on the radiator
small holes/cracks on the top and bottom res can usually be brazed (butane torch and brass rod)
if its a hole in the core... its a tougher operation probbly left to a expeirenced rad repair shop
(usually consists of removing top and bottom resevor and weldin (brazing in most cases) the affected tubes closed at both ends)
I think its called Bar's that makes the stuff in the tube.
DO NOT USE THE BARS PELLETS OR ANYONE ELSE'S PELLETS FOR THAT MATTER!!! they will screw you whole cooling system up 90% of the time....look for a clear tube with silver powder inside it.....its called ALUMASEAL....Wal Mart has it for like 2 bucks and its great stuff....works miracles
Look at a parts store, maybe acklands or napa. It's called devcon and I believe it's specially made for alluminum. I used it on the neck of an old yami enduro and it held for 4 years, probably still going!! lol. Biggest issue is cleaning the area to be repaired.
call up your local radiator shop and have it brazed, had it happen to mine. You don't want to start throwing a bunch of crap in your radiator (cooling system). Its bound to fail sooner or later and is contigency to get someone to a radiator shop in the event that it does happen. It ran me $40, a little steep, but it was pressured tested as well to make sure the weld would hold.
or it sounds like you might have a good excuse to spring for a Fluidyne or PWR
1 - 13 of 13 Posts
