Hey guys i was wondering if anybody makes adjustable pitman arms. it might solve my problems from wheels touching my A arms. thanks.
Not that I know of.
I thought that is what the Tie Rods were for?
VIP
Houser makes a stem flag with adjustable steering stops, but you can only use it with a Houser Anti-Vibe stem and not your stocker.
If that is your problem, try adding material to the steering stops at the side of the frame where the pitman arm strikes when you turn to full extreme..........
Discussion Starter #5
Yes thats still my problem the stem bar is straight and everything else.. Now some one said brfore that it was my stock wheels but I really dought it thats my main problem
Is the pitman arm bent? It can bend down and cause problems. Also check to see if the steering stop on the frame is bent.
