Likely the clutch perch switch. If you look at your clutch lever perch, there is probably an empty socket where it was plugged in. I have mine unplugged and zip tied away like that.
Sent from my LM-V600 using Tapatalk
Reactions: 4stroker4life
Thank you @Choppers what does the clutch perch switch do exactly?
It lets the quad know when the clutch is pulled or not. I unplugged mine because it supposedly removes the speed limiter that the quad has programmed in. I haven't noticed much difference.
With the switch unplugged, the quad can jump forward suddenly if you don't remember to pull the clutch when it is in gear and you try to start it. The switch would normally tell the machine not to start when it is in gear and the clutch isn't pulled.
Or something like that.
