I can't tell.. They look silver ceramic and don't have heat shields. I bought it with the exhaust already on. I wonder because I received my Vito jet kit. It recommends with slip on pipe and open air box.. 150/155 3rd clip. full exhaust and open box 155/160 clip in 4th. You guys gave me advise on another thread.. 160/165, 25 pilot not sure which clip? Also the fuel mix screws these come with look good and should allow me to adjust without a tool. Start these in and back out from there? Thanks again for the advise just want the best recommendation to save me time. My house is at 200' I ride at sea level and have an outerwear box cover and Uni foam filter.
We stick with our original advice - Open air box and full exhaust (yours are not stock headers) = 160L/165R, 25 pilots, Vitos needle at 1 notch rich of center, fuel screws at 2 or 2.5 CCW from lightly seated. Tweak from there to optimize.
Not the stock header. If the people you bought it from say it is the stock header it could be the gytr header.
There's no mounts for the heat shield Thats enough to say there not OEM. Plus they look larger in diameter.
Thanks I just put a yoshi full exhaust on mine, I already have the vito kit, so I will try you advice here, thanks!!
One clip from rich of center is up one on the needle or 2nd (needle sits higher)?.. Allowing more fuel. Thanks.. Ill use the advise.
i think you got your adjustment backwards..The lower the clip postion(3rd or 4th) clip down pulls the needle ouut the main jet more freeing up fuel area...
Yes you're correct. I was thinking backwards.. So 4th position if the top of the needle is the 1st
