1 - 12 of 12 Posts
I got my ASV lever today and was wondering why everyone switches to the YFZ perch before I install them? My lever says it is for a YFZ perch but it should fit my Raptor Right?
Jay
Discussion Starter · #2 ·
No one runs ASV Lever :3question:
Jay
Jay
the YFZ lever is thicker. You'll have to open up your 700 perch a bit....which could give you problems with "not-so" smooth operation, due to the surfaces not being flat anymore.
Well, that is no good. ATV Galaxy sold me a set of levers and the clutch lever says it is for the YFZ. So they basicly sold me something that will not work :mad:.
Jay
I just installed myASV clutch perch and lever combo last weekend, and it works great. I did have to change the start button to the other side of the perch because when I pulled the clutch lever, it hits the start button housing. I'll try to get a pic later and post it. It is a universal ATV setup.
Grant
I think I figured out what happened here. I jsut went back Ebay and looked at the auction that I won (buy it now) and it says right there that what I bought was the Brake Lever and full Clutch Lever and Perch. So I need to call ATV Gallaxy and find out where the hell my perch is.
Jay
hey desdak, were did u get ur asv levers from?
I bought the set Clutch lever/Perch and Brake lever from ATV Galaxy on Ebay. The clutch is a universal unit and you will have to get rid of the switch that is used for starting. I paid 138 shipped for the entire setup.
Jay
I didn't have to remove the start switch, i just loosened it and slid it towards the center about 2 inches and put the perch next to the grip with a little gap. I havn't ridden with it yet but I think it will be ok, i'll try to post a pic of it later today. Grant
Sorry, I didn't mean the starter switch. I am talking about the little switch in the stock clutch perch that ingauges when you pull the clutch in to start the bike in gear. I believe all you havve to do here is cut those two wires and hook them together and you are done, correct?
Jay
Has anyone put the ASV Brake lever on the 2007 Raptor? I just realized the front brake is ressi is different with it being adjustable and all. The lever I got says it fit the 06 so does it fir the 07?
Jay
1 - 12 of 12 Posts
