Has anyone tried the asv levers with a hot start instead of the Drd reverse lever. I was thinking of trying it . They are cheaper on ebay and give you better levers too all in one.
I have a set of ASV's with out the hot start. When I bought mine last year and had the same thought but wasn't sure about the cable end size and draw span of the lever and the cable. So I just ended up with the non hot start lever. I've ordered a set of ASV pro's with the hot start for my KX, if I think of it I will check it out.
I was told as long as its four stroke it should work because they are supposed to be universal but I dont know for sure. Thanks for teh replay . Anyone else with this type of knowledge?
