Does anyone know the axle bearing NUMBER for 2006 raptor? I don't need the yamaha part number, but the actual bearing number. I can get it when I pull them, but would rather have it before hand so I can buy them and get it all done in one shot.
The UK's fastest Raptor
this is a common question on here.
The bearing is not an off the shelf size. I've seached high and low and always end up in the same place - Yamaha parts, all balls or pivot works. :( I use pivot works. My job used to be bearings so I had a lot of contacts in the trade and they still couldn't help.
Noticed it was a common question, but no one has ever given and actual bearing number. the place I go to has had every bearing I've ever asked for. Figured it's worth a shot if I'm gunna save a bit of scratch
I can't give you a number bud as the old one in my shop doesn't have one. But it's a deep groove ball bearing that is rubber shielded on both sides that measures 40mm x 64mm x 12mm. Your local bearing place should be able to work from that.
