i just got a G-force Axle and im in the proccess of installation and im STUCK... i got the axle in and the brake hub and sprocket hub on but when it comes to put the locknut and c-clamp on im at a loss... i have no clue what order to put the them on.. any body who has put one on it would be greatly appriociated.
john
it goes locknut with the flat side against the brake hub then you have to take a screwdriver to push the c clip on and then tighten the lock nut down
you just have to tighten it down did you put the c clip on the other side also just keep tighten it and it will tighten up and when you put in the lock allan bolt put some blue thread lock on it make sure you check it when you ride it might loosen up a little
