Have someone stand on the rear brake. Get the longest ratchet or wrench that you have and put a cheater bar on it. I used the handle off my floor jack. Slide your cheater bar over your ratchet/wrench and give that son of a bitch all you got!
soak it in some PB Blaster before you break out the big wrenches, might help loosen it up a bit.
Discussion Starter #6
thanks fellas now i only have one problem and my damn front brakes wont bleed out. have no front brakes
check the lines. and the calipers
is there fluid in the reservoir? check the lines for leaks. check the calipers as well, like the guy above me said
