I've got an 04' that I bought in july. I noticed that the left rear wheel sticks out more than the right so I measured and sure enough there is a difference, It has Durablue axle and theres a spacer on the left side against the sprocket hub, If you remove that spacer and C-clip the axle is then centered. I'm not sure if I can leave this spacer off or not as there is no shoulder for the sprocket hub to butt up against. The sprocket does get tight onto the axle and the axle nuts get tight but I don't know if it will work loose since there's nothing there for it to butt up against . Has anyone else ran into this? Thanks for any input just trying to figure out what someone else has done
[attachment deleted by admin to free up space]
