Has anyone ever heard of a front arm knuckle having to be replaced?... I have yet to take it apart and inspect but it looks like there is some play where the front arm (Upper) connects to my front arm knuckle... could it be? I was pricing and looks to be an expensive part!..
Well, if you have to replace it, look at replacing the whole set of a-arms. What kind of play?
Check to make sure the nuts are all tightened down.
Well the upper a arm where the ball joint goes into the knuckle I can tighten the nut a long ways above where the pin goes in... Wow its alot harder to explain it than I thought!... (new to this shit)
thats perfectly normal and ok.. just drop a washer on the threads before putting the castle nut down and then it will line up PERFECTLY.. did it with mine when i powdercoated the a arms
