Noticed today that my front tire leans in towards the frame at the top of the tires rotation. I dont think that part is adjustable so im guessing i have a bad ball joint?
Or a bent spindle.
Is it on a jack in the pictures?
See if the tire will wiggle in and out. Have a helper or your dog watch where the movement is.
Also watch your a-arm pivots, they may be bad.
Discussion Starter #3
Or a bent spindle.
It is on the ground in the pic. I raised it and didnt really feel any wiggle in it trying to rock it around. If i spin it raised it does not wobble
What did your dog see or say?
Back a year or so ago, there was a thread about a certain year a-arm that was cheaper then other years by lots, as long as you wanted black.
Or, search used, all 700's as well as from a YFZ450 with carbs, will interchange. Later years have replaceable ball joints, but still fit.
Discussion Starter #5
She wont even look at it. Shes really not much help being so focused on the neighbors cat. I actually have a new set of uppers i bought long ago, most likely because of the thread your talking about. I believe its 2015+ has replaceable ball joints. I kinda assume thats what i need to do but i havnt pulled it apart and wanted other opinions and ideas to check for. Sounds like i need to check the spindle as well
Wow, that has quite the lean to it. Have to check ours out but if I recall they are nothing like that.
Reactions: 4stroker4life
Discussion Starter #7
The other front tire is pretty square so i think i have an issue...
