1 - 11 of 11 Posts
Right side went on easily. The left side is giving me trouble. I twist it in and it is really close but I cannot get it into place. Does it slide in under or over the the outside header bolt?
Sent you a PM. (e-mail actually) - Give me a call.
I just installed mine last weekend.
If you are talking about getting it over those little studs, you just have to hold your tongue right and wiggle a bit and get a litte frustrated with it. Thats what I did anyways and got it in there :lol: Did you replace your header gaskets?
Ok, after about an hour and a half of messing with it I gave up. An hour later, I tried again - but still couldnt get it. An hour later, tried again and still couldnt get it. Then one more hour went by and I gave it one last try. I got mad enough to force into place and POP - I got it in. The pipe was getting stuck between the outside header bolt and the tab on the cylinder. I'm a pretty big guy and I really had to force it on. You can see on the top of the tab were it rubbed when I forced it on.
Anyways, I'm just glad it is on. The only problem I see is that the left side looks really close to the plastic under the airbox. I'll probably get some of that heat sheild stuff and put it over there.
I re-used the original ones. I made sure they were there before I mounted it up.
DuneMe, Thanks for the help. I guess I got a stubborn one :unsure:
After all that - It was 2am and I had to start it up real quick. I only ran it for a couple of seconds (no map yet). I love the low rumble and can't wait to hear what it sounds like when I'm out gettin on it.
Here are some pics.
Thanks for the pics... Now when I get my barker's I have a little better idea of things! :thumbsup:
Bob said:
The left side is giving me trouble... Does it slide in under or over the the outside header bolt?
OK, I know this is an older thread, but it really helped me out with my install tonight. Thanks :thumbsup:
Just in case anyone else is using this thread as reference, the left side is a bit tough...I kept trying to go over the header bolt. It took a bit of effort, but in the end mine went on by sliding it under the header bolt.
1 - 11 of 11 Posts
