If I leave my fuel on,it leaks out the drain on the carbs.this tells me,from what I've already read,float o rings are bad.so I know I need a rebuild or good cleaning on my carbs,just not sure where to start on it or seriously the easiest or best way to pull the carbs out.I also don't really know where to start when I get them out but,its my machine and I really want to be the one working on it.so with that being said any tips?
Read the clear tube method sticky and the other stickies about carbs. I think they are under the mods section. One of them goes through how to get them out and points out what jets are what. It should get you started. Make sure you are carefull taking them apart. There are alot of small pieces and they need to go together the same way they come apart. Good luck =)
Sorry dude i messed up its under the mods section. There are some other ones about carbs to.
