I;m thinking of relocating my battery but un sure where, do to space. is there a battery smaller than stock that has around the same C.C.A? I would like to mount it up front.
hmmm i know why one would put a battery in the trunk of a car
but relocating it on a quad?????
to put more weight in the frontDon't have any pictures, but mine is mounted ahead of the nerfs, just behind the a-arms, with the bottom of the battery level with the lower frame.........
I have no idea.........to put more weight in the front
do people do it on there drag bikes also?
I think it would make sense to put a little more weight in the front end....to put more weight in the front
HD Grizzly battery.......................What's up willy kicker sounds good. What kind of battery are you using and does it put out 200 CCA?
That is correct................Wich would be a Yuasa YTX20HL-BS 310CCA's standard grizzly battery is 270CCA's
