MY raptor has been siting for a few years The jeting hasint been right since i put my ct kit on back in 03, so it's just been chillin. The bike has low hours so do I need to adjust my valve's? I'm going to put the bike in the shop get this thing runing right. I took all the old gas out now I need to chang the oil Befor i bring it in.
Drain the gas and take the carbs off. You'll need to clean them thoroughly. There is a sticky at the top of the 660 modifications forum that will tell you everything you need to know about jetting. I also recommend you set your valves.
Getting it running right will take some tinkering, but won't be too bad. What are all your mods?
Drain the gas, oil ect. I would even do the coolant too. Adjust the valves, change the sparky and then get that thing jetted so you can enjoy it. :thumbsup:
CT Kit, full exhuast, 42 tooth (I think)
