Motosport.com has oem filters for $8Hey Guys,
New to Forum, and just bought a new 2017 Raptor 700R back in Dec 2016, still all stock.
To: xMOWERYx, mattzila, ian77, and BlackSupra all recommending K&N (I'm guessing K&N-145).
I have done only 1 oil change so far and used the oem filter which I bought the same day as Raptor purchase. I ordered the K&N-145 (Amazon $7 vs. oem $14,) that arrived yesterday which K&N's website says the 145 oil filter fits my 2017 Raptor 700R, and it is much shorter than my oem Yamaha filter; I haven't done an oil change or used it yet, however, I do see it's quite shorter than oem.
Did I order the correct K&N-145 filter as it looks much shorter than oem? How will this shorter filter fit snug if it's shorter? I don't recall any springs, bushings, etc... that will take up the slack of this shorter filter. Did you guys have to modify anything? I just don't recall anything within the housing that will take up the slack when I did my first oil change back in January...
Thank you very much for reading this and any suggestions based on your experience with the shorter K&N...
Thanks Guys,
YamiTsunami
Tusk for me. Cheap....They do the same as all the others and if you change your oil regularly there is no need in buying one that is way more.
yeah that would fit much nicer i might have to try oemHey Guys,
t web2007: "Motosport.com has oem filters for $8" Thank You!
ian77, I'll be more than glad to give a pic and measurement here. I guess I just assumed the K&N was much shorter based on some reviews and the noticeable box height difference.
Metal filter caps holding paper element are: KN-145 = 47.5mm / Yamaha 4X7-13440-90 = 49mm, so basically a 1.5mm difference in length. The stem is clearly longer on the Yami oem, but that shouldn't make a big difference since the o-rings on filters are the actual seal.
Visually the actual filters are quite close as the pic will show. Sorry to make a big deal before actually doing a side-to-side comparison; I just was initially going by box height. I will post after my oil change if there's any issues trying K&N vs. Yami since I have them both now...
Thanks for all your replies,
YamiTsunami
K&N filter is tiny bit shorter but it fits anyway. i'll be using them for a long time since I get 'em for a good price at local dealer.Hey Guys,
YamiTsunami
Correct! Good Point! I now recall on the oem even with longer stem re-seating it 2 times before it stayed in place, thus, it would probably be more difficult with the shorter K&N stem as you stated...The stem may make a difference when trying to apply the filter, with the k&n i kept trying to keep it staying level and not falling down while trying to put the cover back on. the added length may make it stand on its own. i only used the oem on my 660 which lasted one oil change and i have only done the k&n on the 700. i may have to do a oem to confirm my theory.
Hi, would the KN145 oil filter fit my 2006 700RThanks mattzila, I appreciate you checking.
I know the KN-145 is correct according to K&N's website, but it being shorter than my oem seems it won't fit snug unless I'm missing something? I don't remember there being anything between crankcase and oil filter cap to compensate, like a spring, for a shorter oil filter. Just don't want to find out half-way through my oil change it fits too loose because it's shorter...
I may just go buy the oem just in case, and then I will post with details of how a shorter oil filter works well, or does not...
I totally believe people posting K&Ns are there 'Go-To' filters that work well, but my OCD is kicking in wondering how a clearly shorter filter fits snug in the space meant for a longer size filter...
Thanks Guys...
Yes.Hi, would the KN145 oil filter fit my 2006 700R
Thanks for your help.
