1 - 20 of 63 Posts
Going broke one quad upgrade at a time
Ok, so next year I'm making my laundry list of things to do to my raptor. Probably going to a higher compression piston, something I can still run pump gas on. Also going to get a +3TB, and a Cam, not sure which yet. Was thinking hot cams stage 3. But..... I hear there are better out there if I get new valve springs. So... Might as well do a port and polish right??? Question is, who gets the most power out of their port and polish? I know an average job will yeild some gain. But I want to know who out there has the reputation for getting the most gain, and still being reliable??? This is a raptor built for all round duning, not just racing, it does get ridden, and it will get riden hard. I also dont want to have to tear it down for valve adjustments all the time... I can find all sorts of stuff for YFZ's saying who does it good.. but no real Rep out there I've found for raptor head's... Let me know what you guys have got... what it ran you....
Who has the best port work?...that all depends on who you ask. My vote goes to Bo white, but there are others that do great work as well. I would contact the experts like Bo, Barker, RE, high desert dyno....all do excellent work, and talk with them, tell them what you want and then go with the one that you feel most comfortable with. Depending on what you want done to the head, they can range from 500 or so up past a grand.
A-10 Crew Chief
I'm going to go with Racers Edge (of course), lol. I'm getting 70hp out of my mild build. P&P with +1 valves ran me $600. Very reliable IMO. But seeing you are in Oregon, it would probably be a better route to just drop it off at HDD at let Daniel work his magic! :D
Daniel at HDD, Beau at Team Rocket Factory, and the king of bling are all very close to me... Such a difficult decision.
I see you're an A-10 Crewcheif... U still in? I work E&E on F-15's
A-10 Crew Chief
Yep, I'm still in. I was curious as to where you knew BOHICA from, lol. The story of our lives! You wanna trade bases? :D I miss Oregon...
All the companies listed offer great port jobs. Though I do think Kenz has a special going on for CNC. And HDD is very close to you, great option. Hard to say anyone's the best, but I'm sure you'll get plenty of PM's telling you where to send your head to and why a certain place is better :lol:
We have lots of openings. Look on USA Jobs for Kingsley Field, OR. It's an Air National Guard Base, but we are full time. We train F-15 pilots. And you can palace chase from active duty.... Just an option. Athough there isn't crap out here in Klamath Falls. LOL.
A-10 Crew Chief
Yeah I was born and raised all over OR so I know the place well. Sure do miss it! Oh, and the $600 for my head also included clearancing for the webb4. Happy shopping!!
Dr Dune
I think we can all agree that there are a few companies here that do top notch work.
I also think it is invaluable to have a builder that's within a reasonable range, and that should be your choice. What starts out as a head, turns into something more, and more, etc, which is why it's so beneficial.
My vote goes to Daniel at HDD, and being close to you makes it even better. Our loss down here in the the Southwest corner of the US is the gain of the Northwest region!
Cola Crew
+1 on all the builders, I have a Bo +2 head and he did a great job on it.. I too think that Daniel at HDD is just to close to pass up... or RE ,Kenz :) You know they are all very good.
I personally had amazing success with Kenz, he really opened up the head and my before and after dyno was a gain of about 12HP if I remember correctly. Probably the best bang for the buck!
So far your the first to be able to give a HP gain on yours... Is that an estimate, or did you guys dyno that day? I'm wondering what I'll see and if I should go + anything on it... +1 +2 +3...
Dr Dune
Well that's becuase it's a loaded answer. Look at this example, say Builder 1 ports a +2 head for you and you slap it onto a bone stock 700 - stock compression, cam, stock bore etc. Take that same head, and put it on a Raptor with all of the extras - high compression piston, big cam, larger bore, etc, and you'd have different results. It's more about the combination of parts than the part itself, only as fast as your slowest team member so to speak!
Your best bet is to call the actual builder and let them explain. You'll hear 1,000 different opinions here, mine included.
Good luck with the build!
I would say that most builders in a build for build sense are going to be in the same ballpark for power. Comparing apples to apples that is. Most of the heads all perform real well. I have to agree it going to all depend on the build. Figure out what you want for a build and what kind of $$$ you want to spend on a build. Then make your decicion on who to use. We have used just about everyones heads out there in exception of Bo's. All builds made great power and very happy customers.
P.s/ Another thing to take into concideration is the person putting it together. Are they going to slap it together not measuring anything? Are they going to degree the cam? Are they going to go for true comp ratio? There is alot to be had if your trying to squeeze every last bit of power out of a particular build.
Just my .02 I still like the feel of a nicely built sb/ss may be slower but seat of the pants feels fast. :thumbsup:
Bo,Barker,or HDD all great porters. I ran a HDD head and a Bo head liked both.
Just a 78HP trail bike
I say google "porting and polishing" and spend a couple of days reading up. You'll only be at the tip of the ice burg, but get your terms right and atleast try to sound like you know what your talking about :lol: Then call up each builder and "feel" out each builder and see which one give you the warm fuzzy feeling. I was in your same shoes 4 years ago and went with Bo White. He's always there to answer a question or just to BS a little.
IMO, all the builder will be pretty damn close if you get the same grade of head. RE, Barker, Bo White, and DL are all great people to deal with!
8SEVENTY3
I went with Racers Edge....they have a CNC machine and have it programmed very well. Their heads are on some of the baddest machines out there, and shipping a head out of state is no big deal. But your question about numbers isnt completely relevant. Im sure if I put a stock head on my build it would drop 20+hp....but if you put my head on a stock bike it wouldnt gain a whole lot. So its all in the right combination of parts, but for something like what youre doing I would go with a +2intake and +1 or +1.5exhaust.
Discussion Starter · #19 ·
That all makes total sense. Different combination of parts will most definately see different results. Just hard to narrow down what to do with my build to get it right. I'm horrible at setting a price limit on a part. Better at finding a price and putting the money together for it. I heard Craz E Deals just sold to someone from Medford that does porting, polishing.. ground up builds. But I dont know much about it. I'll definately get on google for a while. I know the hardest thing for me is the variety of builders I now have withing a couple of hours from me. HDD, King Of Bling, and team Rocket factory, and all have the Rep of being able to build a good solid bike that isn't going to have issues. Thank you all for your advice!!!
I am very good friends with the guy who just bought Craz E Dealz. He and I have worked together for alot of years. I actually had beers with him lastnight discussing the change. I will surely be doing all my dyno work with him now. We will be camped together at Dunefest. Come out and check his Honda 450+R run. He will be out for racing on Friday and Sat and back at the shop to learn the ropes the rest of the time. Go check him out at Craz E Dealz he is a very talented and easy guy to deal with. We are headed over wedensday early afternoon come watch the racing!!!!
1 - 20 of 63 Posts
