1 - 2 of 2 Posts
do the yfz450 steering stems fit on a 01 raptor 660 and if so are they the same size or longer
Same construction, but oem is 1 inch shorter on the yfz. This means that you can use an oem raptor stem on a yfz, but not an oem yfz stem on a raptor. You can however use extended aftermarket yfz stems on the 660.
1 - 2 of 2 Posts
