1 - 20 of 22 Posts
I want to do a big bore kit on my 05 660, but i dont know which one i should do, the 686 or the 720 or the 727? I want it to outrun my friends 08 Polaris Outlaw 525. Any suggestions?
686 will be the cheapest, it's just a bore, hone and piston. The 720 will require a stroker crank, the 727 will require splitting the cases and you should replace the crank while you're in there anyway.
A good port job and a more aggressive camshaft would make the most of any bore increase.
sweet thanx man! Do you think with the 686 it will outrun the Polaris Outlaw 525?
terrain, riders, and what's done to the polaris will have a lot to do with it, but if you had a port job, a cam and a higher compression 102mm piston in there I think you'd have a very good shot at beating the polaris provided it's a bolt on bike or less.
I don't think just putting on the big bore will make it WAY faster. It is the porting that makes there raptors scream assuming you already have the "Big 3" then I would look at porting and a Higher compression piston but the list can go on of what you should do....;) And just a warning I have not found a Cure to the mod bug yet:eek: so be careful.
At what point does someone need to start thinking about FCR's? In otherwords, at what point will the stock carbs be at there limits....
You can always build it up and then when it feels like you top end is lacking pull the trigger on some FCR's. I ran a 720 with a open intake, Sparks exhaust, Stage 3 cam and P&P head on stock carbs and it was still a screamer. I have FCR's now but changed the whole head+porting+cam+FCR's out at the same time so I don't know how much just changing to FCR's does. From what I read on here though its a drastic change.
I've seen a number of builds making low to mid 60 hp numbers on stock carbs. There are some mods you can do to them as well to push it a bit farther.
FCR's are great, but in some cases can double the parts cost of a build. It's all about how and where you want to spend that money. If you've got it then go for it, but it won't be crippled without them.
Im also looking at the 686 kit.Right now im stock with a slip on,filter,and jetted.My plan was to have new guides and springs put in the head with a stage one cam,and a 11.5 to 1 wiseco 686 kit. Im looking for bottome end mostly and just want to know what i can anticipate from this type of setup?????
A few years ago when I first competed in oval track racing I competed with a 660cc with HV porting, dual FCR 39mm carbs, White Bros exhaust with my own head pipes, carrillo rod, and of course the 3 plughead................
I didnt worry about any 686cc, or stroked 720s or 727 big bores. Some had dual exhaust and FCRs...........
I didnt worry about any 686cc, or stroked 720s or 727 big bores. Some had dual exhaust and FCRs...........[/
That doesnt tell me anything! The build I listed is around 1000 dollars. Maybe I should rephrase my qeustion, If you had a 1000 to spend on performance above my current add ons that are in my sig how would you spend it?
You said you wanted to beat a Polaris Outlaw 525, you never mentioned any amount of money. I told you how I beat, ( in oval track racing), the engines you were considering to beat this Polaris, and the engine I used was a stock cc engine with the addons I mentioned................
You said you wanted to be a Polaris Outlaw 525, you never mentioned any amount of money. I told you how I beat, ( in oval track racing), the engines you were considering to beat this Polaris, and the engine I used was a stock cc engine with the addons I mentioned................
mr Willykiller mr fsashemi high jacked mr parknastys thread.. Damn terrorist lol
lol, i guess i did hijack
Discussion Starter · #19 ·
With the 686 big bore kit, would you recommend a Hot Cam stage 3 and a Hot crank 4mm stroker crank?
I have never used a stroker crank yet so I can't really comment on it and as far as a Hot cam stage 3, I have used them extensively along with the X4 cams, great power band, but again I have only used these cams with a 3 plughead..................
1 - 20 of 22 Posts
